Do you want a Keyless Entry Alert Tone?
Old Jul 26, 2011 | 11:46 AM
  #201 (permalink)
corfire's Avatar
Default Re: Do you want a Keyless Entry Alert Tone?
Originally Posted by check
Hi guys,
I'm writing from Germany and I want to install also the siren.
But the problem is, Radioshack is only in the US.
So what would you suggest?
Is this item also possible?
Piezo-Summer KPI-Serie Geräusch-Entwicklung: 85 dB 12 V/DC Stromaufnahme: 15 mA 3.7 ± 0.5 kHz im Conrad Online Shop
85db
3700 Hz
15ma
12 V
Thank you for your help!
It looks like that would work fine.
Old Jul 28, 2011 | 01:04 AM
  #202 (permalink)
check's Avatar
thanks for your help
do you think the sound is the same or at least similar to an original lock/unlock from US cars?
Old Jul 28, 2011 | 07:29 AM
  #203 (permalink)
dtinker's Avatar
The XF I have never worked. This is very pleasant in sound tone and strength( loudness)
Old Jul 28, 2011 | 10:24 AM
  #204 (permalink)
corfire's Avatar
The original Crossfire’s didn't have any sound. I came up with the Radio Shack Mod for less than $5. Someone else found that when they replaced a broken actual siren with a newer version, the sound was included with that new siren. If you search, you will find information about part numbers for the sirens. However, the new version has become quite expensive.
Old Sep 27, 2011 | 11:18 PM
  #205 (permalink)
Mrmiata's Avatar
Just did your mod..HATED looking to see that the lights flashed on arming! Installed the 065 p/n and thought "no way".. went and bought the 95 decible. Guess what, polarity does matter! It's all good though. 12 bucks later I chirp, and actually like the louder tone. Another 2 cents worth, there is a screw above the fuse box that holds the rubber seal in place for the hood. Back it out about 1 turn, place module on bottom side and tighten screw. Figure facing down will help prevent any moisture problems.
Old Oct 3, 2011 | 06:55 PM
  #206 (permalink)
killerkanadian's Avatar
Thanks for this thread. Crossfire now has a Keyless entry tone
Old Nov 1, 2011 | 05:31 PM
  #207 (permalink)
austinboyette's Avatar
I have tried everything to make this work on my Xfire. I have the Piezo 273-073 Part, and had everything hooked up right and it didnt work. I pulled the fuse and everything. Need some help here please.
Old Nov 1, 2011 | 06:47 PM
  #208 (permalink)
Mrmiata's Avatar
(A) Your not on the correct terminals of the relay (look at pictures again)
(B) You got a bum buzzer
(C) Footnote: if you say "what was that" when it does chirp..switch polarity!
It really is this simple. Um... I'm just "assuming" your lights are flashing when locking... If not then you have another issue involved.
Old Nov 1, 2011 | 06:54 PM
  #209 (permalink)
PitMarshall's Avatar
What exactly do you mean when you say, "I pulled the fuse and everything" ? You know that the fuse has to be installed for this to work, right?.
The notion of whether or not your lights flash is a good one. Check all four to ensure that they do flash and that the doors /trunk actually are locking.
If they are, re-visit the post again and follow it carefully.
Old Nov 2, 2011 | 11:22 AM
  #210 (permalink)
No. I pulled the fuse before installing it, and put the fuse back when I was done. My lights flash and everything and the buzzer does not go off. I have tried it with another buzzer and it did indeed work. But the sound of the other buzzer was a siren and not the sound I was looking for. I tried hooking the Piezo 273-073 Buzzer to a 12 V Battery and nothing happened, so I am starting to think I got a Dead Buzzer, but Radio Shack is out of stock since I got the last one.
Old Nov 2, 2011 | 02:39 PM
  #211 (permalink)
klong's Avatar
Piezo Element 1500-3000Hz - RadioShack.com
RS says that you need an external driver for this buzzer.
KL
Old Nov 2, 2011 | 03:24 PM
  #212 (permalink)
On page one of this thread, it did not mention anything of that. It just stated where to wire everything to and which pins, which is pin 85 and 86. So where would I get this driver?
Old Nov 2, 2011 | 07:19 PM
  #213 (permalink)
Mrmiata's Avatar
95dB Panel Piezo Buzzer
Model: 273-075
| Catalog #: 273-075
This is what I'm using..the difference between being a buzzer and an element? And it leaves no doubt "did it chirp"..lol.
Old Nov 2, 2011 | 09:56 PM
  #214 (permalink)
dtinker's Avatar
Sousa like it is the buzzer,siren or what you want to call it. The device you bought eitgher is bad or needs another device to work.
Old Nov 20, 2011 | 01:08 PM
  #215 (permalink)
coolx's Avatar
By the way, I also did this with the hood in the 90* position. For those who do not know, this can be done by pushing a button on the top of the hood suspension rod. Then press the button on the bottom of the rod to release it.
Hey, I just want to thank you fellas for your posts - 04 INFERNO - thanks for that little nugget on the the hood rod. I'm gonna do the modification for the keyless entry alert, I've already got my buzzer from radio shack but before I proceed I thought I'd review the postings about it...and I learned something new, now I can open my hood all the way - thanx fellas
Old Nov 20, 2011 | 01:48 PM
  #216 (permalink)
Mrmiata's Avatar
Hope you purchased a buzzer listed that has been used by other members. Then you won't have to worry about the driver module thing!
And if you haven't already done it, The speaker capacitor mod is very cheap, easy, and makes a nice difference if your still using the stock stereo system!
"Edit": I actually just fed the wires through the holes on the relay contacts and plugged back in.. has worked just fine.
Old Nov 20, 2011 | 05:37 PM
  #217 (permalink)
coolx's Avatar
Cool Re: Do you want a Keyless Entry Alert Tone?
Mrmiata - I used the RS 059 buzzer, considering going for thr 060 if it's louder. driver module? speaker capacitor mod? tell me more...
Old Nov 20, 2011 | 05:52 PM
  #218 (permalink)
Mrmiata's Avatar
https://www.crossfireforum.org/forum...-buck-mod.html
You could skip down towards the end on this.. was a must do after finding out I could just pop out the little cover panel on the door. (visible when door is open..tucked next to dash when door is closed).
Seems the user just above your postings bought the wrong type buzzer and per radio shack write up was supposed to be used in conjuction with a driver module of some sort.
Old Nov 20, 2011 | 06:17 PM
  #219 (permalink)
coolx's Avatar
[quote=Mrmiata]https://www.crossfireforum.org/forum...-buck-mod.html
Ok, now I know what you were talking about regarding the driver module. I have the original stereo/CD/navigation unit. It can do ALOT of stuff so I'm gonna keep it. I have the same issue with the bass distortion as pekeld 1 had so I,m gonna look into the crossover mod - thank you mrmiata! I really, really like this forum. I've had my crossfire for almost two months and so far I've done the throttle body reset (worked great) and the keyless alert - looking forward to many more projects...
Old Nov 20, 2011 | 06:26 PM
  #220 (permalink)
Mrmiata's Avatar
I've had mine about 4 months now. Bought my Miata off the showroom floor in Nov. 90 and was so passionate about it, it was unreal. And now that passion for a car is back.. lol. This place is great, just take some time to read through a lot of the older post, you will learn a lot. And use the search engine if you have an issue or questions. Just about everything has been asked and answered at some point I think.(Some get testy when a question is asked for the 50th time..lol)
