Originally Posted by dtinker
I just went out and checked my XF to see if it honks the horn when the turnsignals are activated. Mine does not do that. Still works as intended. Mybe something is shorting out on the wires wrapped around the relay spades or at the connector?
Thanks for the quick reply!
Either way i'm going to be doing this tonight..will update with my results.
I assume if I use the # 85 & 86 pins it should be fine.
Thanks,
Eric Henderson
