Old Apr 8, 2008 | 07:03 PM
  #69 (permalink)
bikecop's Avatar
bikecop
Default Re: E85 converted SRT-6
Did I hurt your feelings?
Originally Posted by apkano
Just research stoichiometric ratio.
Timing does not = HP. Advanced timing allows more fuel to be introduced to the cylinders and still accomplish a complete burn. If the mixture is too rich (too much fuel) then the combustion takes longer. Too lean of a mixture causes the fuel to ignite under pressure (dieseling). There's a fine balance between a condition called "lean-roll" which is ideal, and being lean to the point of detonation.
I would think that people with enough mental power to make observations and commentary on people they know nothing about should at least be able to wrap their mind around this simple concept.
