E85 converted SRT-6
Old Apr 9, 2008 | 08:33 AM
  #81 (permalink)
sonoronos's Avatar
Default Re: E85 converted SRT-6
Originally Posted by apkano
Just research stoichiometric ratio.
Timing does not = HP. Advanced timing allows more fuel to be introduced to the cylinders and still accomplish a complete burn. If the mixture is too rich (too much fuel) then the combustion takes longer. Too lean of a mixture causes the fuel to ignite under pressure (dieseling). There's a fine balance between a condition called "lean-roll" which is ideal, and being lean to the point of detonation.
I'm going to be gentle here, apkano. Almost everything you stated is just plain wrong and/or explained very poorly. AFRs around 12:1 is where max power is made under boost. Advancing timing changes where on the piston/rod stroke the power is applied to the crankshaft. Closer to TDC means more average energy output onto the crankshaft. Dieseling is caused by compression of a fuel-air mixture and can happen whether rich OR lean. Too lean of a mixture can cause pre-ignition and/or knock, which is not just dieseling. Pre-ignition occurs due to a lot of things, but in addition to dieseling, it is often due to super-hot carbon deposits. Knock is basically an explosion of the fuel-air mixture, as opposed to a "burn" which one would find in a normal ignition situation.
Again - timing has nothing to do with how much "fuel is introduced into the cylinders." That has to do with your injector pulse, injector flow, and fuel rail pressure. Timing is all about where on the piston stroke the fuel burn occurs. Too soon after TDC and the dynamic cylinder pressure will cause ringlands to blow out or rods to snap. Too long after TDC and the burning fuel/air mixture doesn't have enough time to push on the rods enough to generate any kind of power.
This may just be a case of "you know what I mean vs. what I actually said", so don't take it personally. But compare the information you stated to the information in a book like "Maximum Boost" and statements like "Timing does not = HP" are just plain wrong.
Old Apr 9, 2008 | 08:44 AM
  #82 (permalink)
sonoronos's Avatar
Originally Posted by bikecop
Inmotion is sending me out two new chips with a more aggressive timimg curve. I will data log them both to watch for any negitive readings.
Timing is the key. I can guarantee that you'll feel the difference once the timing is advanced and you're running on 100% E85 @ 105 octane.
Old Apr 9, 2008 | 09:21 AM
  #83 (permalink)
bikecop's Avatar
http://www.youtube.com/watch?v=PWlpgdTwj2E
Here is a video of me at the track. Sorry my son was trying to watch for a moment and moved the camera. Listen as I am halfway down you can here my tires start to loose traction. The car I am running is a modded Trailblazer SS running slicks with all wheel drive. He had a 1.7 60ft. to my 1.83
He ran a 12.70 @ 106 to my 12.46 @ 112.43
Old Apr 9, 2008 | 09:43 AM
  #84 (permalink)
cruzinquick's Avatar
At least your times are consistent and that's on stock tires right? DR's will knock at least a tenth off. I would assume the same agressive ECU tune would work with racing gas of the same octane equivalent. That's good for the track to be able to swap out chips. I asked before, how much more are the extra chips?
Thanks,
Cruzinquick
Old Apr 9, 2008 | 10:19 AM
  #85 (permalink)
apkano's Avatar
Life is random...so am I.
Maybe I wasn't clear enough before, for that I apologize. I was trying to teach a bunch of guys how to convert milliseconds to cycle times, through a language barrier, when I wrote that. I understand all too well how an engine works. I still stand by the fact that timing does not equal horsepower. The basic point I was trying to convey was that you can change base timing, timing curve, fuel, etc., but if you're not generating the highest rate of thermal expansion immediately after TDC, you're just wasting time.
Truth be told, compression ratio is the key to horsepower. Just look to some of the baddest engines around......top fuel. Granted, they burn Nitromethane, which burns slower than gasoline, stoich is somewhere around 1.7 or 1.6 to 1. The timing is at 60 + degrees BTDC. This allows them to achieve a longer combustion cycle. These guys are burning over 3 gallons in a quarter mile. Halfway down the track the spark plugs are basically fried, and they have a diesel engine in effect.
The biggest changes they make in these engines is the CR. Copper head gaskets are sized by the thousandths of an inch, and most teams have a huge selection of them.
Old Apr 9, 2008 | 11:02 AM
  #86 (permalink)
bikecop's Avatar
Yes, my tune that I am using now is for 95 octane or there abouts so a 100 octane tune should work for either. I can't remember how much the tune was but I paid for a custom one so I think another chip was included. James from Inmotion has been a great guy to deal with. He also has a lot of past and present history with racing and tuning cars. One of which was an alcohol car. I would give James a call to check prices.
Thanks,
Cruzinquick
Old Apr 9, 2008 | 11:21 AM
  #87 (permalink)
hoofbeat's Avatar
If anyone wants to understand the relationship between timing and horsepower should Google horsepower and timing and look at the webpage from Ford Muscle and the effect of timing/timing curve to gains in horspower.
Old Apr 10, 2008 | 02:57 AM
  #88 (permalink)
Steve Hellums's Avatar
I watched your video when I got home from work yesterday, you have one fast SRT 6. I'm almost affraid to do a side by side run, because if you spanked my RENNtech tuned SRT 6, I would have to call RENNtech and tell them a dude with just an INMOTION tune opened up a can of whoop a$$ on me and I'm not very happy about it .
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
miscetera
Oct 5, 2015 11:40 AM
