Thread: At the track...
Old Apr 9, 2008 | 04:07 PM
  #75 (permalink)
distantpulse's Avatar
distantpulse
Default Re: At the track...
If anyone is interested, here is the time slip from my last run. I had to photoshop(poorly) the numbers in as it was too blurry to read. I do not have a scanner and i took a pic of it with the iphone(which is not great for photos). Sorry! Anyway, like I mentioned the only mods I have are the NW Intake and the ASP 178mm pulley. I cooled the car for about 30 min in between runs. I went into the waterbox a little below the notch at the half mark. Did my burnout through 2nd and staged the car at 1600rpm. DO NOT idle in the staging lanes while you wait to make your run. 11's should not be that hard to obtain with a couple of more mods! I've said it before, but the key to good runs is a well prepped track and a good launch technique to get those 60ft times down. You guys with more mods than I have should go on a day where you KNOW there is going to be glue sprayed on the track as well as actual race cars running. They warm the track and lay down rubber. Do this and I would be interested in seeing your time slips
