Originally Posted by tylerxfire
no problem, so you are saying not to go before the ninety degree angle, but if i were to go after it i believe it will be too close to throttle body which i don't know if it makes a difference, i just am told it should be 6 to 18 inches away from throttle body and i think it would be closer than that.
were you told it hurts the car? because for performance, the dyno is the same as the jet number, 75 jet is 75 hp after 20% conversion.
