Spraying Dry NOS on N/A limited
Old Apr 12, 2008 | 08:10 PM
psuperti's Avatar
Default Re: Spraying Dry NOS on N/A limited
Originally Posted by tylerxfire
so how about describing or giving better pics of your nozzle where it is mounted and where you tapped in for fuel
Why are you talking me this way?
I'm in Iraq I can't take anymore pictures for you.
Old Apr 12, 2008 | 08:24 PM
tylerxfire's Avatar
whaaat!!!, maybe you took me wrong or something but i don't know where you are coming from there, um. . ok i thought perhaps you would have taken more pics besides the ones posted on the website which arent too clear of where certain things are, and i am in the process of getting my system all hooked up and looking for a little advice or possibly pics which would help alot, i can't tell where you are spraying your nozzle from your pics, and i do not want to put mine on the ninety degree angle before the throttle body, no need to be all joe cool about it, i am just looking for a little friendly advice from you, i see that certain things may be going to your head. guess i will find friendly advice elsewhere, just thought maybe coming from someone who has a nitrous install could be a great help to my few questions, then again i thought thats what this website was for. I am a marine and i do not know what you are doing over there but i too was there and there is no need for the hostility to start because of a few questions, also read into it i did say thanks, bad day maybe, but i thought in your post it said here to help, THANKS
Old Apr 13, 2008 | 01:15 AM
psuperti's Avatar
its cool, my apologies. don't spray before the 90 degree angle and you will be fine. take care.
Old Apr 13, 2008 | 01:04 PM
tylerxfire's Avatar
no problem, so you are saying not to go before the ninety degree angle, but if i were to go after it i believe it will be too close to throttle body which i don't know if it makes a difference, i just am told it should be 6 to 18 inches away from throttle body and i think it would be closer than that.
Old Apr 13, 2008 | 07:44 PM
psuperti's Avatar
were you told it hurts the car? because for performance, the dyno is the same as the jet number, 75 jet is 75 hp after 20% conversion.
Old Apr 14, 2008 | 09:31 AM
tylerxfire's Avatar
no just going by instructions it says 6-18" i don't know the difference it makes
55chevy
Jul 22, 2024 02:31 PM
Reliableron
Oct 17, 2015 10:19 PM
cppeabody
Sep 15, 2015 08:43 AM
xfireon20z
Sep 10, 2015 04:27 PM
BEATv1
Sep 10, 2015 12:58 PM
