Old Apr 15, 2008 | 12:32 PM
Maxwell's Avatar
Maxwell
Default Re: Experimenting with Toluene
there are oil sprayers under the pistons, I remmember HDDP said this cars oil runs the oil at a very high temp, hence the reason why we need synthetic oil, other wise this motor would coke up.
if you can get the the oil temp down with a larger oil cooler, the oil will absorb more heat from the pistons, thus cooling them further, and alowing more timing advance on the ignition. those of you who are getting ecu tunes, your putting more timing in your maps, so your burning the fuel longer in the cylinders which adds more heat to the piston. so you want to remove as much heat from the pistons as possible, thus the reasoning behind why the SRT6 has an oil cooler. more pressure=more heat= more detonation for that CR
so you can make more hp if you add more timing, but if you add more timing you might get detonation because of the pressure is heating the fuel too soon, so you reduce the pressure by taking the heat away from the piston, and avoid hot spots on the piston so you avoid pre-ignition. now you can add more timing due to resistance for detonation.
Originally Posted by sonoronos
Maxwell,
Can you explain what you mean by "too hot from the oil sprayers" ? I must be misunderstanding you because that doesn't make much sense to me.
Since the oil is operating at 200-225 degrees, it should always be cooler than the temperature of the combustion chamber.
As far I understand, an oil cooler is used to radiate excess heat put into the engine oil by the combustion process. This in addition to the coolant. This is why modifying thermostats rarely does anything in this car - the amount of heat dissipated by the engine is limited by the radiator and radiator fans, not by the thermostat.
Therefore, the oil cooler is only a must IF the engine makes more power. It doesn't go the other way around (cooler oil=more power, that isn't right at all.)
