Old Apr 18, 2008 | 07:27 AM
Stogey's Avatar
Stogey
Default Window alignment !
The window on the passenger side is not aligned properly to gasket on upper most rear corner of the window. The corner of the glass is probably a 1/16 of inch from lining up flush with the rear glass. Seems like you could easily slide a business card in between the window and gasket. The doors is aligned to the body as close as I can tell, so I guess my question would be, is there an adjustment inside the door panel to bring the rear edge of the glass in towards the gasket ?
I know there are TSB's out there, but my ride is outta warranty, just wondering if anyone has had the same issue and addressed it ?
