Temperature indicator
I have swapped in the 180 stat that I have been reworking. It works but I made an error by not recording the position of the temperature gauge before the change.
My sensor now shows middle scale to 1/2 'notch' below middle on the gauge. This is with the weather at 75 degrees and several short hard runs on it. The infrared thermometer I used shows that the outlet radiator hose is about 180 degrees.
Wish I remembered to note the reading before I got all involved with the change.
What does your temp sensor read normally, thank you and enjoy, Woody
