Temperature indicator
Old Apr 24, 2008 | 03:44 AM
waldig's Avatar
Question Temperature indicator
I have swapped in the 180 stat that I have been reworking. It works but I made an error by not recording the position of the temperature gauge before the change.
My sensor now shows middle scale to 1/2 'notch' below middle on the gauge. This is with the weather at 75 degrees and several short hard runs on it. The infrared thermometer I used shows that the outlet radiator hose is about 180 degrees.
Wish I remembered to note the reading before I got all involved with the change.
What does your temp sensor read normally, thank you and enjoy, Woody
Old Apr 24, 2008 | 03:49 AM
Default Re: Temperature indicator
Mine reads just slightly below the half way mark on the gage all the time while driving.
It occasionally creeps a little above when in heavy traffic on a 90 degree day. I don't think these other thermostats make much difference although I don't have one. It just seems that the posts on this subject don't show any change in the position of the temp gage.
Old Apr 24, 2008 | 04:00 AM
REVIT93RX7's Avatar
My gauge reads 1/2 or slightly below. I live in FL and even during summer driving it has never gone above 1/2.
Jim
Old Apr 24, 2008 | 04:47 AM
SRT-6 Steve's Avatar
That is too high for going through the trouble for a swap. Should only be around 1/4 to 1/3rd up from the bottom or cold position. Most read a needle or two width below half way with the stock stat.
Steve
Old Apr 24, 2008 | 06:03 AM
240M3SRT's Avatar
My needle commonly resides just ABOVE the 1/2 way point.
Old Apr 24, 2008 | 07:06 AM
NeverEnough's Avatar
In stop and go traffic and during hard running, mine always is about a needle width above the 1/2 (middle) mark. I put 2 bottles of Water Wetter in the system and that def. helps it cool down quicker and runs cooler during normal driving, but it still creeps up there when I am "having fun"
Old Apr 24, 2008 | 07:21 AM
BlackJax-SRT's Avatar
My daily driver stays about like this (here in sunny FL), but once I get out on the highway (and get back into "normal" drive mode), it quickly drops to the needle-width below.
Old Apr 24, 2008 | 08:58 AM
sonoronos's Avatar
So here's a question - what temperature is the engine coolant temperature measuring?
The temperature of the coolant in the engine...
or the temperature of the coolant in the radiator?
Old Apr 24, 2008 | 09:08 AM
ProjectMayhem's Avatar
My question is why did you go with a 180 t-stat, why not go for a 160 t-stat thats the number most of the guys who do t-stat swap go with.
Old Apr 24, 2008 | 09:12 AM
Stogey's Avatar
It reads the temperature of the coolant in the engine
Old Apr 24, 2008 | 09:25 AM
huudoo's Avatar
mine reads just a needle notch above 1/2 sitting in traffic, 81 degrees outside
Old Apr 24, 2008 | 09:36 AM
sonoronos's Avatar
Well then, the problem is obvious - the radiator fan must spin longer and/or the radiator must increase in size.
Old Apr 24, 2008 | 11:35 AM
waldig's Avatar
Talking Re: Temperature indicator
Thanks for the responses so far. I wanted to go conservative on the first pass. The modification is easily done using the Stant stats as there is a series that fits the housing with minimal changes.
I did not go to 160 because I believe that it may be too cold for the computer, LET Jerry possibly will fill in for me here.
Stant stats ( that I chose ) are listed in their book as follows:
13006 160
13007 170
13008 180
13009 190 all in degrees F.
Since they are physically the same you can pick and choose for your personal choice. I will be doing 2 days of autocrossing and after all the big pieces come back without distress Ill release my approach and photos.
I want to be my own test subject first under full power testing conditions. I will also be able to report on the bigger H/E and LET 181 pulley upgrade as I did them this past weekend along with 4 HID lamps that were also installed during the same Thash.....
Enjoy;
Woody
eikon
Sep 9, 2019 10:16 PM
northwest_crossfire
May 30, 2016 05:19 PM
waldig
Sep 17, 2015 10:35 AM
Reevz1977
Aug 23, 2015 09:28 AM
waldig
Jul 30, 2015 07:39 PM
