Re: center console
that just seems photoshopped to me... has anyone ever seen that in person... cause i just don't see where the modification was done... i think the center console may have been extended up to accomodate the dual din.
edit: took a closer look. found the modification. looks as though the cut into the dash and raised up the vents and a/c controls. if you look, you can see the top of the vents is not in line with the lines on the glovebox... which if i'm not have a brainfart right now, are lined up on my xfire.
