Old May 7, 2008 | 08:45 PM
Moparrbust's Avatar
Moparrbust
Default Test runs at the track tonight.
I finally got a chance to test the car out with the new E85 conversion and 185 pulley. I made two passes before calling it quits due to running lean up top and not wanting to push my luck. First........the ambient temperature was 87* with a 4742 DA. The car at WOT was running consistant 12.2 AFR all the way up to 5500rpms in each gear and from 5500-redline it was at 14.5-15.0 AFR. I had already cranked up the E85 computer to it's highest fuel setting(10) and the car's ECU has been untouched. Here's all the data from my second(last) pass:
coolant temp: 1 line below half mark
tires: Hoosier DRs with 17psi and 1900rpm launch in 1st gear ESP off
gas: Full tank of E85 with 3 gallons of 91pump
boost: 16.9psi peak
EGT: 1850*
AFR: 12.2 to 5500..........14.5-15.0 5500 to redline
60': 1.833
1/8: 8.130
mph: 86.44
1/4: 12.613
mph: 110.37
