Old May 9, 2008 | 05:25 AM
amx1397
Default first mod and it is free
I was looking at the air intake where it comes through the radiator support and through the grille if you put your hand through the grille ,,try to reach the air intake hole in the radiator support, you can't the grille has a upward peice if the grille that forces the air upward, (I am talking about the second vertiablebar in the grille) well i cut it on each side of the hor, bar and then heated it and bent it stright now i can almost touch the intake hole and the next vert. bar below it still has the sweep in it with this mod only i will test it on the track and see if it improves the ait to the SC. I know there is twice the amount of air getting to the opening than before. jim
