Old May 9, 2008 | 07:29 AM
amx1397
Default Re: first mod and it is free
Originally Posted by amx1397
I was looking at the air intake where it comes through the radiator support and where air flows through the grille. if you put your hand through the grille( you can't) ,,try to reach the air intake hole in the radiator support, you can't ,the grille has a upward peice of plastic.. it forces the air upward, (I am talking about the second vertical bar in the grille) well i cut it on each side of the horizontal bar and then heated it and bent it stright, now i can almost touch the intake hole at the radiator suport and the next vertical. the bar below it still has the sweep in it. with this mod only i will test it on the track and see if it improves the air to the Supercharger. I know there is twice the amount of air getting to the intakes than before. jim
reread this I corrected the typing, maybe my fast one finger typing is not the best but the mods i do are the best. jim
