Old May 10, 2008 | 11:00 AM
Xfire fan's Avatar
Xfire fan
Default Re: first mod and it is free
Originally Posted by drydock
Ok, sounds fine except on a rainy day. Be prepared to ingest water.
Yesterday 01:01 PMamx1397
useing the stock intake system even if water got into the opening there is a hole in the bottom under the filterdor drain anything that gets in there ,,, with my car running i just took a water hose and tried to get water into the intake ,by spraing water directly at the intake holes in the grille,, hood colsed reveing the motor and spraying,, ,,nothingwas found under the filters, but got some draining(drops) under the slincers where the corgated hose connects to the filter housing on both sides you would have to be in a hurricane to get water into the intake, and i don't think it would happen then either. jim
This is post #17 from amx1397.
