Re: Fuel Injectors / Rail
Stock injectors are measured at 15.5 lbs/hr @ 3bar, our cars run at 4bar however. This effectively makes them a 17 lbs/hr stock, but at their upper limits. We replace with 17 lbs/hr @3bar which is about 19 lbs/hr at 4bar.
We also provide spacers and longer bolts to make everything work like stock. Injectors are a black/silver combo and blend in perfectly with the engine compartment. Unless you were looking, you wouldn't be able to tell anything has changed.
Anthony
TVT Design
