Old May 18, 2008 | 05:19 PM
  #135 (permalink)
HDDP's Avatar
HDDP
Default Re: Fuel Injectors / Rail
Originally Posted by splinter
+1 on stevieb and TVT_DESIGN
Per HDDP, whose shared intel I regard highly:
NA ENGINE: 17 lbs/hr at 3.8 Bar, or 55 psi/ 14.5 ohms.
SC ENGINE: 51.6 lbs/hr @ 55.1 PSI / 14.5 Ohms based on 380 kPA = 3.8 bars = 55.1 PSI
They’ll plug…but they certainly won’t play.
Yes, that info is from Bosch USA directly. And you are correct, throwing the SRT6 injectors onto the fuel rail physically fits and will run the engine at idle in open loop... Step on the gas and it chokes. I just happened to test it with the injectors for my SRT6 engine...
