Dome LEDs Flicker When Window is Used!?!?
Hello, I have recently installed LEDs purchased from Autolumination.com in the Dome, and Trunk. I had the Dome lights installed first and had no problem. I thought that they looked so good that I absolutely had to get one for the trunk. Once I installed a 39mm LED in the trunk which I needed to adjust the housing to fit, I noticed that when the power windows were used the dome lights would flicker... What's up with that??? Could it be that I am not using the recommended 44mm bulb, or that the combined usage of the LED's low energy usage allow an excess of electricity to flow through the interior which triggers the dome lights... I have no idea... ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED!!!
Thanks,
~Mike~
