Dome LEDs Flicker When Window is Used!?!?
Old May 28, 2008 | 07:36 PM
Arnotm1's Avatar
Question Dome LEDs Flicker When Window is Used!?!?
Hello, I have recently installed LEDs purchased from Autolumination.com in the Dome, and Trunk. I had the Dome lights installed first and had no problem. I thought that they looked so good that I absolutely had to get one for the trunk. Once I installed a 39mm LED in the trunk which I needed to adjust the housing to fit, I noticed that when the power windows were used the dome lights would flicker... What's up with that??? Could it be that I am not using the recommended 44mm bulb, or that the combined usage of the LED's low energy usage allow an excess of electricity to flow through the interior which triggers the dome lights... I have no idea... ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED!!!
Thanks,
~Mike~
Old May 28, 2008 | 07:47 PM
maxcichon's Avatar
Default Re: Dome LEDs Flicker When Window is Used!?!?
Yeah, yeah. My eyebrow LEDs flicker randomly too.
What to do?
Old May 29, 2008 | 03:29 AM
amcordo's Avatar
Ah yes, welcome to the issues with LEDs in Crossfires! You'll notice that if you replace the license lights with LEDs, they'll start to flicker pretty quick as well whenever you've got the parking lights on but the vehicle off. I replace them, they work fine for another three months then I repeat.
Old May 29, 2008 | 05:19 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
i have the same problem with my dash lights.. i hit the window switch and the dash lights dim.
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
AlbertFattal
Sep 24, 2015 05:03 AM
