Re: will i run lean with an ecu tune?
The basic ECU flash leans out the fuel trim on these cars to make power, along with advancing the timing.
A CAI and exhaust will be pushing the stock injectors to the lean side. A really good breathing exhaust changes the AFR dramatically on these cars.
You will need larger injectors to see the most out of those mods and a tune. Expect about 25-30 HP more with the injectors then without.
Anthony
