Old Jun 11, 2008 | 08:34 AM
NoCones's Avatar
NoCones
Default Re: Front tires wearing on outer edges:
Originally Posted by danimal
A good alignment shop should be able to compensate (at least a little). Have them check the wear pattern, check the alignment against specs....and then adjust accordingly to help aleviate some of the wear. You may be surprised at what they can do (if they've got their stuff together) and how much you will save on tires.
Front camber is not adjustable (without swapping to the notched correction bolts).
