Front tires wearing on outer edges:
Old Jun 10, 2008 | 01:33 PM
Jeff Cobb's Avatar
Default Front tires wearing on outer edges:
Both of my front tires with about 6500 miles on them are showing a good bit of wear on the outer edge.
My car still tracks straight and true. Rear tires look fine.
Could this be a camber issue or just a natural side effect of thrashing twisty mounatin roads?
Thanks in advance.
Old Jun 10, 2008 | 02:02 PM
danimal's Avatar
Default Re: Front tires wearing on outer edges:
I think it is probably just nosing it into the curves a little hard.......I tend to do the same thing when I'm up there.
Old Jun 10, 2008 | 02:06 PM
Jeff Cobb's Avatar
Thanks Dan. I'm about due for an oil change so I'll get them rotated then.
Old Jun 10, 2008 | 02:23 PM
chuck65's Avatar
I agree with danimal but rotating won't help. Both your fronts are 18" and the back are 19". I hope you know that.
The only thing that will happen if you put the 19's on the front is that your coffee will stay more level in the cupholder when going downhill.
Old Jun 10, 2008 | 02:40 PM
Jeff Cobb's Avatar
Thanks, Chuck, but I was talking about left to right rotation. The inner edges on the fronts are not showing unusual wear, just the outers.
Old Jun 10, 2008 | 02:54 PM
chuck65's Avatar
You must have meant dismount from the rims and turn to get the inner side to the outside ? Make sure that you have multi directional tires. Some tires are designed to only rotate one direction and can't be reversed.
Old Jun 10, 2008 | 03:06 PM
Jeff Cobb's Avatar
Drat. You're right Chuck.
I've got Nitto Invo's with an asymmetrical tread pattern.
http://www.nittotire.com/#index%2Etire%2Einvo
No way to dismount and flip 'em.
I guess I've found a new maintenance cost.
Oh well, I'm still going to push it on these mountain roads; not quite the Tail of the Dragon, but there are quite a few fire breathing geckos to slay.
Do you think lowering my car to get a negative camber would be of much help?
Maybe I should go with 18's all around.
Then I can rotate, save money when I have to replace those pricey 19's and get better acceleration. Still, I'd hate to mess up the look.
Old Jun 10, 2008 | 03:25 PM
danimal's Avatar
Don't mess up the staggered look.....
A good alignment shop should be able to compensate (at least a little). Have them check the wear pattern, check the alignment against specs....and then adjust accordingly to help aleviate some of the wear. You may be surprised at what they can do (if they've got their stuff together) and how much you will save on tires.
Old Jun 11, 2008 | 08:33 AM
NoCones's Avatar
Yes, that would help.
You don't necessarily need to lower though. The factory correction bolts will get you 4 or 5 tenths of a degree.
Old Jun 11, 2008 | 08:34 AM
NoCones's Avatar
Front camber is not adjustable (without swapping to the notched correction bolts).
Old Jun 11, 2008 | 09:32 AM
Jeff Cobb's Avatar
Thanks for the advice guys.
Kodebuster
Nov 5, 2020 04:06 PM
cdcrone123
27
Sep 24, 2015 11:28 AM
cdcrone123
Aug 4, 2015 06:37 PM
Bayukbros
Jul 29, 2015 10:16 AM
cjfine
Jul 20, 2015 11:58 PM
