Originally Posted by Charles Moore
Any suggestions about what would cause the uneven wear(the rears are equally worn)? What would you replace them with?
Originally Posted by Thomas B. Whyle
I have exactly the same situation with regard to wear (I have the Pilot Sports).
you will always have more wear on your drive tires... this is because the torque the engine produces is place mainly on those rear tires (RWD). This means the friction and surface heat made between the street and your tire is much higher in the rear than in the front cause more stress on the rear tires and thus cause them to wear quicker....
educated $.02
