Originally Posted by ChuckNorris
7000x1.7=11,900rpm, My engine will never see 7000 rpms
inmotion can remove the speed govorner, also tvt can do this too I'm guessing
that would make 500cfm, at 180F and about 40hp at around 11,9k rpm, sounds fun!
found some specs and rebuild part numbers for the m90.
http://thunderbirdinfo.blogspot.com/...build-and.html
porting mods for the eaton sc.
http://www.sccoa.com/articles/blowerbuild.php
12.88 second Thiunderbird SC mods as follows, but it is a heavy **** car too...
Modifications:
2.2 Liter Kenne-Belle (Autorotor AB) Blower
'03 Cobra Intake
90MM Lightning MAF
Accufab 1600 CFM Billet Throttle-Body
K&N Conical Filter
APTEN Laminova Triple-Core Liquid IC
Lightning Heat Exchanger
Lightning Intercooler Pump
Moroso Cool-Can
Wise Racing Engines Shortblock
Ross Racing Pistons
Total-Seal Plasma Piston Rings
Eagle 351W Rods
Polished & Balanced Crank
Multi-Layer Steel/Ceramic Head Gaskets
APTEN Custom-Bypass
Aeromotive AFPR
Steigemeier Ported & Polished Heads
Steigemeier Custom-Ported Intake
Oversized Intake & Exhaust Valves
Custom Blower Inlet-Plenum
Alcohol-Injection
CMRE Custom Cam
CMRE Chromoly Pushrods
CMRE Bronze Valve Guides
CMRE 1.73 Rocker Arms
ARP Studs & Bolts
ESM Billet Aluminum Jackshaft-Pulley
ESM Custom Fuel System Including Braided Stainless-Steel Lines
ESM Billet 5/16" Fuel-Rail Connector
Twin 255LPH Holley Fuel-Pumps
42LB Fuel-Injectors
ASP Underdrive Pullies
Trunk Mounted Battery
Griffin Lightweight Aluminum Racing Radiator
Magnacor 8.5MM Wires
Kooks 1 7/8" Stainless-Steel Headers w/ 3" Collectors
SCP "Big-Dawg" Exhaust System w/ Borla Resonator
180-Degree Thermostat
Tuning By APTEN Technologies
