Old Jun 14, 2008 | 02:13 PM
ChicagoX's Avatar
ChicagoX
Default Re: Just a thought about how to cool the inlet air
Originally Posted by waldig
... Ok but on the other hand I really do not see that the intercooler flows thru the water tank, there are common inlet and outlet connections; however the pumps circulate in their own circuits and I wonder how much actual fluid is intermingled, swap spit as it were...
They do have individual circuits, with a cross-over. You can separate them fairly easily with the addition of a dedicated IC reservoir/overflow tank. The Benz guys have done this for awhile, with excellent results. BrianBrave seems to like it as well.
I do come back on to my original plan to get a cooler engine via a better tstat. I have most of that and need to adjust the computer so that the fan will run and drop the block temp. Typically I get the temp needle to the second mark or a full mark below the middle....
I don't have my modded t-stat yet, but LET adjusted the computer to make the fans come on earlier. Be careful not to make it too cold, or you will trigger a CEL when it takes too long to go into closed-loop. What is your target temp?
As spock's computer used to say: Working!
Nice ST reference.
Kudos to you AND BrianBrave for the initiative and creativity.
