Do you want a Keyless Entry Alert Tone?
Jun 17, 2008 | 09:12 AM
64
permalink
corfire
Dec 2007
392
Rathdrum, Idaho
Re: Do you want a Keyless Entry Alert Tone?
Quote:
MUTT
a little late on this post, but i just ran a wire from the #87 pin (see diagram in the first post of this thread) directly to my horn. now horns beeps along with the lights when arming/disarming.
Yes, that certainly is an option, if you want a horn honk. You are then using the relay contacts to operate the horn, instead of the voltage across the relay coil to make the tone buzzer sound. I suggest that you make a very good connection (solder or crimp), because the horn will require much more current (several amps instead of just milliamps). Just wrapping the wire for the horn, as I did for the low current buzzer might (probably will) create a high resistance connection resulting in heat at that connection. That was and is one of my concerns about operating the horn with the keyless entry relay. Making a connection to the wire running to the receptacle for #87 would be the best way to connect if you can find it under the fuse box. Working with the higher current devices requires very good electrical connections.
corfire
View Public Profile
Send a private message to corfire
Find all posts by corfire
