Old Jun 20, 2008 | 06:31 PM
  #65 (permalink)
brain_26's Avatar
brain_26
Default Re: Factory Alarm Chirp! Solved! Read!!!
Originally Posted by NJCrossfire05
12mm to remove nuts off of wipers
T20 torx bit to remove the crowl
4” gear puller from pep boys $24.00 to remove wiper arms
14mm to remove bolt of alarm housing from car.
TX30 security bit to remove siren from housing.
Lessons learned: The bolt to remove the siren housing is pictured below with the socket wrench with the red handle. It is on the exterior of the crowl.
#1 Remove wiper arms using 12mm socket and gear puller.
#2 Remove crowl using a T20 torx (star bit). 7 torx screws.
#3 Remove the siren housing from the car first.
#4 Remove siren from housing using the TX30 security bit.
#5 Turn on car to deactivate alarm. (I blew out my ear drums)
#6 Carefully remove wire from siren do not use a screw driver. I did and broke a retention clip.
#7 Plug in new siren and shut off car to avoid a second degree burn to your elbow.
I was worried about attaching the wiper arms but they just pop on and tighten up with the 12mm nut. No sweat, however you must use a gear puller to remove them! Do not try to just pull them off it won’t work.
All in all it took about an hour with the right tools and I like the tone. I will try and figure out a way to post the tone here soon.
Also read Iamfink2 post and clean out your drains!
Do you have a name brand, or price info on the TX30 security bit? Your information has help a lot, and thanks for posting it as well.
