Old Jul 1, 2008 | 08:40 PM
NeedsWings's Avatar
NeedsWings
Default datalog screen shots
in case you guys have never seen this type of thing, here is what we use to record the...
air/fuel ratio
rpm
boost
throttle position
ect...
this was a 1st to the middle of 4th gear pull, the gas pedal was planted the entire way, notice how the t/c pulls back the signal to the throttle body when the tires break loose (the car did not go into the "fall on its face" mod either, it was un-noticable while driving).
also notice the boost curves thru the gears. it was fairly warm out today hence the lower psi we were seeing (we peaked around mid 16psi today instead of the mid 17psi we see when its cool out).
we have a little more fine tuning to this calibration to do and then it should be ready for you guys to get a reflash from inmotion with it.
i can email out the real file so you can move the vertical line and watch all the values all the way thru if anyone is interested
