Old Jul 30, 2004 | 05:46 PM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default
i purchased the hid kit you have in your crossfire and i am having a problem...i hope you can help.
the factory H7 bulb has some depth to the rear of the bulb housing (metal) so the factory retainer clip to has pressure to hold the bulb in the headlamp housing. with the new xenon kit the housing of the xenon bulb has no metal backing (rubber) or depth to keep pressure on the bulb when attaching the spring/retainer clip into place. how did you manage to keep the xenon bulb securely in the headlamp housing without being loose? thank you for any input.
andrew
