Old Jul 11, 2008 | 09:01 PM
MikeR's Avatar
MikeR
Default Got the Dyno done on the Aero
I finaly got the Aero in and got a Dyno done with the SL55 intake and the 181mm pulley. See the Mustang dyno sheet below. They did three pulls and they all came out pretty close to the same. The first pull he only went to 5500rpm as I thought it would car would limit there with no front wheel movement, it didnt, the max rWhp was 297 and rwtrq 304. The second pull he went to redline and the max rwhp was 307 and rwtrq was 294. Pull number three was pretty much the same but he started out lower rpm and when the covertor kicked in it through some BIG spikes on the front end of the graph that through the peak and avg numbers all off. After the spikes it tracked the same as the frist two. The A/F avg was 11.5 with a max of 12.3 both runs 1 & 2. Max boost was measured in inches of mercury = 62". Not sure what that is in PSI.
So 307 rWhp max and 300 rWtrq for basic numbers before the ECU gets tuned by LET.
MikeR
File Type: psd
File Type: psd
