Got the Dyno done on the Aero
Old Jul 11, 2008 | 09:01 PM
MikeR's Avatar
Default Got the Dyno done on the Aero
I finaly got the Aero in and got a Dyno done with the SL55 intake and the 181mm pulley. See the Mustang dyno sheet below. They did three pulls and they all came out pretty close to the same. The first pull he only went to 5500rpm as I thought it would car would limit there with no front wheel movement, it didnt, the max rWhp was 297 and rwtrq 304. The second pull he went to redline and the max rwhp was 307 and rwtrq was 294. Pull number three was pretty much the same but he started out lower rpm and when the covertor kicked in it through some BIG spikes on the front end of the graph that through the peak and avg numbers all off. After the spikes it tracked the same as the frist two. The A/F avg was 11.5 with a max of 12.3 both runs 1 & 2. Max boost was measured in inches of mercury = 62". Not sure what that is in PSI.
So 307 rWhp max and 300 rWtrq for basic numbers before the ECU gets tuned by LET.
MikeR
File Type: psd
File Type: psd
Old Jul 11, 2008 | 09:11 PM
SRT6nTulsa's Avatar
Default Re: Got the Dyno done on the Aero
Nice run. What was the temp/humidity?
Old Jul 11, 2008 | 09:16 PM
MikeR's Avatar
The temp outside today was about 85. Dont know what the humidity was, probably about 50%. We are in Oregon. It has been hot and sunny here for the last week though(85-95).
MikeR
Old Jul 11, 2008 | 10:08 PM
BrianBrave's Avatar
<--- Huge Horsepower
Those are some good numbers. According to my conversion 62 In. of Mercury is like 30.45 PSI and your AFR is well within the safe range.
Looks like you got yourself a screamer...
** EDIT **
If the shop was near an airport, you could get some weather and altitude info and use this calculator to get the corrected density altitude for a better PSI conversion.
http://wahiduddin.net/calc/calc_da.htm
Old Jul 11, 2008 | 10:15 PM
alfdoc's Avatar
Thumbs up Re: Got the Dyno done on the Aero
Hay Mike, The next time you go to the dyno let me know , i would like to be there.
Old Jul 12, 2008 | 05:55 AM
MikeR's Avatar
alfdoc, I will be taking it back after the ECU tuen. I'll PM you when I get it scheduled.
MikeR
Old Jul 13, 2008 | 11:49 AM
alfdoc's Avatar
Thanks for the reply , what did it cost for the dyno run ? I mite get a base line done on mine.
Old Jul 13, 2008 | 12:42 PM
waldig's Avatar
Wink Re: Got the Dyno done on the Aero
Brians reading of 30.45 psi is accurate, you need to consider that the atmosphere is about 29.96" of mercury normally; or as the old Colonel ( of KFC Chicken ) used to say in his commercials fourteen and 7/10 pounds. That works out to 15.75 psi boost.
I was going to post this earlier but the 5th grader that helps me with number and math was riding his bike till now.
Enjoying, Woody
Old Jul 13, 2008 | 12:44 PM
SRT6 Gang Member's Avatar
THREE 6S
Smile Re: Got the Dyno done on the Aero
Excellent pulls and thanks for posting. Its great to see the car maintains a good A/F with the SL55/ 181 setup under a full load.
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
Sep 28, 2015 07:40 PM
Billy22Bob
Sep 18, 2015 08:57 AM
RacerXofFL
Sep 15, 2015 05:00 PM
