Originally Posted by sonoronos
The Motec 600, as a standalone ECU, can make the engine do anything - even run in a state that would make it blow up (such as advancing the timing to dangerous places in the piston stroke or changing the ignition sequence.)
you are misinterpreting what I asked, I meant to say can it phase the duel ignition so that it also can fire another spark 10 degrees after the first ignition for the same cylinder.?
