Old Jul 27, 2008 | 07:10 AM
HDDP's Avatar
HDDP
Default Re: Couple NA Tech questions
Originally Posted by Infinite
I'm currently undergoing a twin turbo kit on my xf... nothing over the top.. just enough to make it a fun driving car
im just wondering if anyone has found out what the stock MAF flow limit is?
just how strong are the factory internals?
again, setup so far is twin ct12a's w/ a ceramic turbine wheel
depending on what i can get away with timing wise probably no more then 8-10psi which should net a healthy 300crank or so
i'll be making the headers, downpipes, exhaust, intercooler piping and such myself, so no problem there
and if i cant get away with a simple AFC hack then i'll probably just toss a haltech on it
All fine and good, your internals will handle that boost. But, how are you manipulating the ECU/PCM to run the engine ? Therein lays your problem...
