Old Jul 30, 2008 | 05:33 PM
Steve Hellums's Avatar
Steve Hellums
Default Re: Bought used SRt6, replace intercooler pump?
Originally Posted by Punkin
Woody,
I am waiting for a LET exchanger, johnson pump, and intake spacers from "the toy" and wanted to change them at the end of my warranty. I have had the pump replaced to correct the typical issue but didn't think about getting the old pump for the PM. Sorry just wasn't thinking CSI at the time. If these new additions are not going to gain me anything such as performance, longevity, etc. I may just forget about it. I eagerly await the publishing of youre research.
BOY WOODY, THAT WAS A MOUTH FULL .
Punkin this is a little off the subject of the I/C pump, but one reason I did not choose to get a larger heat exchanger is because they were thicker and I didn't think they could be much taller than the OEM. That being said you are not going to increase the surface area for air to flow through. I have never seen how close the larger heat exchanger's sit's to the A/C condencer, but I know the OEM sit's 1&1/4 inch away from it. I'm just guessing, but I believe it was designed that way so air can flow through it. If the larger/thicker heat exchanger is sitting pretty well against the A/C condencer that would prevent air from flowing through it. I agree with cruzinquick, I would think the larger heat exchanger would not help much in daily driving or drag racing. I moved my OEM heat exchanger forward enough to install a couple cooling fans to try to make it possable to control my I/C coolant temp's to make more consistant runs in drag racing. I also have a digital temp gauge with the sending unit mounted in the heat exchanger, AMGJerry rode with me down the track a couple times with a data logger plugged in and said my gauge was the same reading as the I/C coolant was on the data logger.
