Originally Posted by Steve Hellums
I hate to disagree with you, but here is a slip with the guy on the left running a code 3 pulley, code 3 HE and an Inmotion tune plus a custom intake. I'm the guy on the right with a RENNtech 178 pulley, stock HE, SL55"Y" and an "out of the box RENNtech ECU tune".
This is one run though. You can't base it off just one run. Your mph's are fairly close which is a big indicator in how your car is performing. He had a 2.11 60?! That is way off! Either he spun really bad, or like Mrphotoman said, he was having trans problems. Regardless, I bet he would have been closer to you with a good launch and setup. I don't think he would have won, but I bet he would have been a car length from you at the finish if you were both equal on the tree.
