Old Aug 7, 2008 | 05:47 AM
  #55 (permalink)
distantpulse's Avatar
distantpulse
Default Re: 20% Off Code3 Products
Originally Posted by Steve Hellums
When I talked with Brandon about a month or two ago about running his S/C pulley with my 178 crank pulley, he said it create's a little too much heat and wouldn't advise trying to do so. The more boost you have the hotter the the air, so the ECU will start pulling timing & start dumping the fuel to it to try to cool it down. So that being said, I think you would loose performance trying to run them together.
Yes it would create more heat, but a nice water/meth kit along with other cooling mods (HE, spacers, T-stat, etc...) should be very complimentary to this combo of pullies. This is what I plan on doing.
