Old Aug 8, 2008 | 08:45 AM
DesertFox's Avatar
DesertFox
Default Re: Going with NOS...
Originally Posted by SRTpowa
This will help save your motor
http://www.latemodelrestoration.com/...0%201&comp=LRS
a WOT/window switch
I have a brand new one I will sell for $150. I have decided to not run N20. I allso have I brand new dry kit I will probally sell for $350.
Also a wideband, colder plugs(have some brand new NGK's from LET to sell as well), and a fuel pressure switch if running a wet kit would be a good investment.
+1. If you're gonna run nitrous, you better run one of these window switches at a bare minimum. The only thing I would verify is whether traction control will reduce the TPS signal that you're tapping into (I think it should, but double-check).
