Old Aug 9, 2008 | 06:10 PM
SRTFreak's Avatar
SRTFreak
Default Re: Code 3 supercharger pulley
Originally Posted by SRT-6 Steve
Does anyone know what changed to not use the spacers? It came with three. I believe you would experience a slight rub due to not enough space between the new pully and the clutch. The stock spacer is very thin and there is only one. Not saying it won't work this way but I believe you really need to check the spacing.
Steve
Steve
I asked Brandon ( Code3 ) about him not using the spacers on the new pulleys. He said that the time the first batch got off the line the tail end of them had gotten off by a couple 1000th of an inch. So the solution was to use spacers. The newer pulleys are measuring to spec.
