Code 3 supercharger pulley
Old Aug 9, 2008 | 06:10 PM
SRTFreak's Avatar
Default Re: Code 3 supercharger pulley
Originally Posted by SRT-6 Steve
Does anyone know what changed to not use the spacers? It came with three. I believe you would experience a slight rub due to not enough space between the new pully and the clutch. The stock spacer is very thin and there is only one. Not saying it won't work this way but I believe you really need to check the spacing.
Steve
Steve
I asked Brandon ( Code3 ) about him not using the spacers on the new pulleys. He said that the time the first batch got off the line the tail end of them had gotten off by a couple 1000th of an inch. So the solution was to use spacers. The newer pulleys are measuring to spec.
Old Aug 9, 2008 | 07:26 PM
SRT-6 Steve's Avatar
Originally Posted by SRTFreak
Steve
Thanks, I appreciate the iinfo. I used three spacers.
Steve
Old Aug 9, 2008 | 07:28 PM
Originally Posted by BLKFIN
I just installed a boost gauge this week and have not had a real chance to open her up, but the most I have seen in the lower gears in 15lbs. When are you seeing 17lbs? The top of third gear?
Hi BLKFIN, Do you have any pictures? Did you do the install?
Steve
Old Aug 10, 2008 | 08:43 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Steve
I will take some today and post them in my Gallery. I will send you a pm once I have them up. I did the install....not too bad. I had a little free time when Jerry had my ECU. I finally had a chance to see 17lbs of boost yesterday~
Old Aug 10, 2008 | 11:23 AM
Eleventeen's Avatar
Even the factory pulley uses spacers, so if he got them spec'd out so well that none are needed, then he's done a pretty good job.
Old Aug 11, 2008 | 03:28 PM
well, you use the ones that are already on there...so there are spacers (shims)...just don't need more....
TOPLESS
Feb 9, 2016 11:28 AM
UNDER PSI
Nov 1, 2015 09:39 PM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
Sep 25, 2015 02:16 AM
