Code 3 supercharger pulley
Old Aug 7, 2008 | 06:46 PM
franknbeans's Avatar
Default Code 3 supercharger pulley
Searched but couldn't find. Sorry.
How much hp does a Code 3 supercharger pulley add? Also, is there anywhere I can go to do some research? Sticky? website?
thanks and sorry I'm a noob.
Old Aug 7, 2008 | 06:50 PM
RPM's Avatar
RPM
Moderator
Default Re: Code 3 supercharger pulley
http://www.code3performance.com/
Old Aug 7, 2008 | 06:52 PM
Thanks!
Old Aug 7, 2008 | 07:46 PM
any place to read up on detailed info?
Old Aug 8, 2008 | 03:17 AM
RPM's Avatar
RPM
Moderator
Quick search - https://www.crossfireforum.org/forum...703#post251703
Old Aug 8, 2008 | 08:16 AM
DesertFox's Avatar
If you're gonna buy it within the next week, don't forget to use the 20% off coupon.
Also, Cliff's notes: a 178mm crank pulley will make more boost than the SC pulley, but the SC pulley is much easier to install
Old Aug 8, 2008 | 01:15 PM
bikecop's Avatar
They make the same boost, and maybe even more. I always see 16-17 lbs of boost. And yes, they are way easier to install.
Old Aug 8, 2008 | 01:44 PM
BLKFIN's Avatar
ADDICTED TO BOOST
I just installed a boost gauge this week and have not had a real chance to open her up, but the most I have seen in the lower gears in 15lbs. When are you seeing 17lbs? The top of third gear?
Old Aug 8, 2008 | 01:54 PM
mrphotoman's Avatar
the pulley is so easy to install it is rediculous. about a 10 minute job.
there are threads on the pulley all over this forum with more info.
Old Aug 8, 2008 | 02:16 PM
DesertFox's Avatar
I thought I came across calculations based on the SC pulley's diameter that showed that it was equivalent to <178mm crank pulley in terms of overdriving the supercharger (and that was with the 65.03mm of the 1st gen pulley, not the 65.3mm measured from newer pulleys). Then again, my memory's never as good as it was. I'll have to dig that up somewhere.
Old Aug 9, 2008 | 08:44 AM
trying to find out if shims are still needed for code 3 pulley install or not...I didn't get any shims w/ the pulley, so before I start, thought I would ask...pm'd bikecop...just waiting to start...
Old Aug 9, 2008 | 09:54 AM
Bubba89's Avatar
i received one shim with my Code3 pulley but ended up not having to use any after i checked all the tolerances so you should be fine
Old Aug 9, 2008 | 11:27 AM
thanks,, bikecop got back to me...just wanted to make sure before I take it off...thanks, Bubba...
Old Aug 9, 2008 | 11:29 AM
Voyager's Avatar
so oledoc it sounds like the shims are no longer needed. is that right?
Old Aug 9, 2008 | 11:33 AM
yes sir, that would be correct, just re-use the old one that is already there...
Old Aug 9, 2008 | 11:35 AM
Voyager's Avatar
good to know thanks
Old Aug 9, 2008 | 11:39 AM
this is what makes this forum grt......I will get to try her out on the way up to WWDC...decided not to put on new wheels and tires until after WWDC and US41...might as well finish off the old ones first....
Old Aug 9, 2008 | 12:44 PM
SRT-6 Steve's Avatar
Does anyone know what changed to not use the spacers? It came with three. I believe you would experience a slight rub due to not enough space between the new pully and the clutch. The stock spacer is very thin and there is only one. Not saying it won't work this way but I believe you really need to check the spacing.
Steve
Old Aug 9, 2008 | 02:07 PM
SRT6nTulsa's Avatar
In the 3 days I have had my car this summer, I have been very pleased with my Code3Performance pulley. A friend of mine who used to have the Renntech kit says that it feels exactly the same.
Old Aug 9, 2008 | 06:05 PM
srt6-Steve...I will check spacing as I re-install, but that was what I was told to do...won't do the install until Monday evening now...so if you hear of something different...that's what I intend to do...
