Old Aug 10, 2008 | 12:15 AM
Playdrv4me's Avatar
Playdrv4me
Default Re: I disconnected my IC Pump and... nothing happened...
Originally Posted by Voyager
it sounds like to check to see if the pump was bad he disconnected it and it felt the same. if thats the case its a good way to check and see
Yea Voyager you're exactly right...
With all the consternation over this pump I was like well, I see there's an electrical connector, so let's see what happens if I just turn the thing off... If nothing happens I know something is broken, and sure enough, no change.
My *only* worry before I did this was that seeing as how coolant flows through it, I wasn't sure if disconnecting it would cause coolant to stop flowing through the system, but nothing happened, temps stayed the same.
