I disconnected my IC Pump and... nothing happened...
Old Aug 10, 2008 | 10:46 PM
limeysrt6's Avatar
Default Re: I disconnected my IC Pump and... nothing happened...
Im quite new at this whole IC pump business, where on the car is it located ?
Old Aug 10, 2008 | 10:50 PM
70GT6's Avatar
Passenger side - in front of the front wheel, behind inner fender well - outside edge of radiator.
Old Aug 11, 2008 | 08:45 AM
cruzinquick's Avatar
Originally Posted by ohnoesaz
Thats what I was thinking, and it makes me even more anxious to install my ford pump when it arrives..... This car is definately fast, heck it puts my Mustang GT to shame, but I feel like there is something there thats lacking when compared to the youtube clips I see and stories you guys tell.
Yep it's the needswings intake and crank pulleys. By the way after a few months even that power seems lacking. That's the curse of always wanting just a little more power.
Old Aug 11, 2008 | 08:52 AM
Originally Posted by Playdrv4me
I agree, I just don't drive the car hard enough or race it to where I need the reliability and robustness of the Johnson unit. The Ford one is a little cheaper and easier to install, and fits in the same spot.
There is no extra power from the Big Johnson unit or any other cooling mods you add. If you see Vadim's (from VRP) graph on the mb forum it shows the negative of having too much flow.
Old Aug 11, 2008 | 04:11 PM
limeysrt6's Avatar
so the lightning pump is better than the johnson pump as far as installing and fittin in place ?
Old Aug 11, 2008 | 04:29 PM
70GT6's Avatar
The lightning pump is a twin to the factory SRT pump.
You just need to switch tops to get the right hose outlet diameters and the wire connector is brand specific and will need to be modified -simple stake on connectors will work (I added wire so I could save the factory connector and soldered the wires to the pump. Then used gasket silicone to fill the socket for a water-tight connection)
Old Aug 5, 2009 | 05:57 PM
martyfa's Avatar
I need to replace my IC Pump. Which is the better pump to go with the Johnson or Ford Lightning?
Old Aug 7, 2009 | 03:57 PM
Montana Crossfire's Avatar
Going to a Ford part on our SRTs in kinda Blasphemy Where as the Johnson pump sounds like a specialty company that builds pumps for very special applications and special cars...
I like the design of the Johnson pump myself.
Mike
Old Aug 7, 2009 | 09:00 PM
Yes x2. It's a bosch part not a Ford part. Heck why does it matter? Remember it's a chrysler. LOL. Mine is working fine and I gained 40hp . At least there isn't a johnson faster than mine. Way to resurrect from the dead thread zone.
Old Aug 11, 2009 | 08:26 PM
xfire06's Avatar
glad I saw this, I think my pump is going out
Old Aug 19, 2009 | 09:36 PM
Rokypoky's Avatar
I take it this means it's shot?
Disconnected the electrical supply from it completely the other day and drove around all day, noticed no difference in acceleration at *ALL*, so I'm assuming it's done for.
Also someone suggested it coule be responsible for lurches when cruising too, which its been doing more now and at lower speeds, like 30-40mph all of a sudden Ill lurch forward all of a sudden for just a second. This is not the same as the tiny lurch I was talking about in another thread when just taking off, but this one is when actually cruising.
Anyway, I guess I'll be getting a johnson pump eventually or a Ford Lightning SVT unit and adapt it on the cheap.
I am also having the lurches when cruising. I took it in to the dealer but they couldn't find the problem because their not a computer light or code. Sure wish I could find the problem be it's the pits. Drove all the way to and back for W.W last week end with this happening.
Ask the need wings mech. about it but he didn't no.
Old Aug 19, 2009 | 09:48 PM
32krazy!'s Avatar
Originally Posted by Rokypoky
I am also having the lurches when cruising. I took it in to the dealer but they couldn't find the problem because their not a computer light or code. Sure wish I could find the problem be it's the pits. Drove all the way to and back for W.W last weed end with this happening.
the thing most dont realize with the bosch i/c pump isnt will it fail but WHEN will it fail! its junk whether its on a mercedes or x/fire or ford lightning. get a cm30 and replace it. if it hasnt failed yet its only a matter of time
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
