Old Aug 11, 2008 | 04:29 PM
70GT6's Avatar
70GT6
Default Re: I disconnected my IC Pump and... nothing happened...
Originally Posted by limeysrt6
so the lightning pump is better than the johnson pump as far as installing and fittin in place ?
The lightning pump is a twin to the factory SRT pump.
You just need to switch tops to get the right hose outlet diameters and the wire connector is brand specific and will need to be modified -simple stake on connectors will work (I added wire so I could save the factory connector and soldered the wires to the pump. Then used gasket silicone to fill the socket for a water-tight connection)
