Old Aug 10, 2008 | 01:31 PM
cruzinquick's Avatar
cruzinquick
Default Re: I disconnected my IC Pump and... nothing happened...
Your welcome. The johnson pump will require you to make changes to your hoses. I believe the inlet and outlet are just a little bigger than the stock hoses. Maybe someone else can chime in. Also the stock bracket that holds the ic pump will have to be modified to hold the larger johnson pump.
