Old Aug 11, 2008 | 02:01 PM
calxfire's Avatar
calxfire
Default Re: Coolant change info?
Originally Posted by ohnoesaz
Hey guys... I've read the specs for the coolant, buts its confusing compared to most cars. Is there an aftermarket off-the-shelf brand that meets the specs that you guys already know of?
And... For draining, just drain the radiator, which will include the block, and drain the aux pump to get that seperate system also?
Tehe thanks.
The owner's manual and service manual says use coolant with GO-5 designation. The only off the shelf brand I have seen so far is made by XEREX and it says GO-5 in big letters in the front of the container.
