Coolant change info?
Old Aug 10, 2008 | 08:04 PM
ohnoesaz's Avatar
Default Coolant change info?
Hey guys... I've read the specs for the coolant, buts its confusing compared to most cars. Is there an aftermarket off-the-shelf brand that meets the specs that you guys already know of?
And... For draining, just drain the radiator, which will include the block, and drain the aux pump to get that seperate system also?
Tehe thanks.
Old Aug 10, 2008 | 08:21 PM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: Coolant change info?
Tehe thanks.
Section 7 of the service manual lists the standard draining and refilling procedures and specs for the anitfreeze.
The manual does mention NOT to use Propylene-Glycol types of additives. They don't provide the required corrosion protection.
This why you should never use other additives like water wetter, etc..
Old Aug 10, 2008 | 09:25 PM
Playdrv4me's Avatar
NEVER use green coolant in German cars... EVER. If you sniff the stuff in German cars you'll notice it has a very acrid odor compared to the sweet odor of green and orange coolant formulations used by Domestic and Japanese manufacturers, and the properties are pretty different.
In fact, if you're ever low, it's a BETTER idea to top off with DISTILLED water than any kind of green or orange coolant.
Old Aug 11, 2008 | 02:01 PM
calxfire's Avatar
Tehe thanks.
The owner's manual and service manual says use coolant with GO-5 designation. The only off the shelf brand I have seen so far is made by XEREX and it says GO-5 in big letters in the front of the container.
Old Aug 11, 2008 | 02:31 PM
ohnoesaz's Avatar
Ah, G0-5. I've had good luck with that in a few Fords. Well, by good luck I mean it did its job and met the specs.... I guess the srt6 needs it for the aluminum build of the engine?
Anyways thanks for the answer
Old Aug 11, 2008 | 02:53 PM
calxfire's Avatar
By the way you will need 4 gallons since the capacity is 15+quarts or liters (I forgot).
Old Aug 11, 2008 | 03:26 PM
sowardcustoms's Avatar
https://www.crossfireforum.org/forum...ad.php?t=23704
Old Aug 12, 2008 | 05:02 AM
Display_Name's Avatar
What coolant to buy?
Coolant - Mercedes Benz Coolant is cheaper than the Mopar stuff.
Turns out Valvoline ZEREX G-05 (Gold bottle?) is also OK (So says the service manual), but it doesn't explicitly meet the MB 325.0 standard.
The SRT6 has a capacity of 15.3 quarts, NA Crossfire's have a capacity of 11.8 quarts, so either way you'll need to buy 2 gallons of coolant, but you won't use it all on an NA system. See coolant bottle for mixing percentages. 50/50 is typical, the other 50 being distilled water.
Link to a photograph showing mixing table on the back of MB 325.0 antifreeze.
https://www.crossfireforum.org/galle...cedes_Part.jpg
Old Aug 12, 2008 | 05:03 AM
4 gallons of fluid, yes, but not 4 gallons of coolant.
2 gallons of coolant (see my post above for coolants that are acceptable).
2 gallons of distilled water.
You won't use it all, but you need more than 4 quarts of each, so buy the second gallon of each.
(This does not include water for flushing the system, if you choose to do so.)
Old Aug 12, 2008 | 07:33 AM
calxfire's Avatar
^^^ You're right it's 4 gallons of fluid, I have only seen Xerex GO-5 in ready to use 50/50 gallon jugs so I posted that he should buy 4 gallons of the stuff. Thanks for the clarification.
Old Aug 12, 2008 | 07:54 AM
BlUEMDsrt6's Avatar
When you flush the coolant, will all of the coolant come out including the stuff in the HE? I have the LET HE and was wondring if I have to disconnect it to finish flushing the coolant or will will it just come out with the rest?
Old Aug 12, 2008 | 08:05 AM
You have to drain the heat exchanger circuit seperately. Its only common junction with the engine cooling circuit is at the top.
I pulled the lines off of the heat exchanger pump, which drained a lot of fluid out. The connections on the heat exchanger itself might drain more, but they aren't easy to get to.
Old Aug 12, 2008 | 08:07 AM
That's funny, I've only ever seen the not "Ready to use" full strength stuff.
http://www.valvoline.com/pages/produ...10&section=405
PNA
Nov 12, 2020 04:44 PM
sittininthesun
Aug 24, 2015 10:47 AM
Rets
Aug 23, 2015 06:31 PM
Ralph289
Jul 26, 2015 12:52 PM
Tp'sfury
Jul 17, 2015 01:15 PM
