Thread: Air con smell
Old Aug 14, 2008 | 04:19 AM
amcordo's Avatar
amcordo
Default Re: Air con smell
Originally Posted by amcordo
I used to have a problem with this. I even bought one of those carbon cabin air filters and it only helped a tiny bit. After doing the following thing for the past month or so the smell is finally gone for good!
When I turn the vehicle off after using the A/C I press the recirculation button on the A/C control panel. The second LED light near the bottom of the button will light up and you'll feel air coming out of the vents. It will run for somewhere between 15-30 minutes (even though the key is out of the ignition) and it dries out your A/C system, which helps to kill off mold and mildew and the bacteria that create that terrible smell. I've done this for over a month now and it doesn't kill your battery.
I hope that works for you as well!
I strongly urge everyone to try doing this. 90% of the folks with the odor issue are smelling the byproducts of bacteria thriving in a cool, dark, wet environment. This feature was installed specifically to dry out the system after use to kill the bacteria before it can create these smells!
