Old Aug 16, 2008 | 05:12 AM
waldig's Avatar
waldig
Talking Re: Are we sure the HE water system 'self burps' itself?
In the course of events leading to my quest for a better cooling system(s) I have drained the coolant several dozen times over the summer.
All above is true, however I have added a relay and a switch to power on my pump at will when the motor is off. I use it to do some testing but have found that the pump runs all the time you are driving, pretty much anyway. Engine on pump on but you want to be wary of the belts and fan start up, so use the clamp below and save a 911 call.
To bleed the system you partially pinch the return hose as described and drive around a bit and you will purge the air pronto. Just driving will do very little as bubbles will stream forth for a long time.
How do you pinch the hose and drive around with out getting hurt?
TA DAAA, get a hose clamp, open it and slip it around the 5/8" rubber hose below (lower ) than the wye at the i/c tubing as shown(aluminum) and tighten it slightly (pinch hose about1/3 closed - 2/3 normal diameter). THis will add enough restriction to raise the pressure in the hose and force coolant to flow into the recovery tank purging the air more rapidly.
Id do this with the cap loose as it will be cool enough to not need it and the lower pressure will make the bubbles more bouyant (bigger). Take a gentle spin down the street or idle for a while and return the i/c pump will be fully on, doing the purge. Stay out of the moving pieces and parts please.
In checking the flow I added the additional return hose to see the progress of this process (photo attached). I could monitor the purge by noting the clarity of the liquid stream. With my 2 square foot h/e it can take a bit of time.
Remember to loosen the clamp, you can leave it on for next time and with this approach you dont need to have the STAR gizmos.
Enjoy;Woody
