Originally Posted by BlueStorm
You missed my point, the lager rear wheels cause understeer and over power the front skinny wheels. if you match the wheels they will reduce plowing.
also if you want more traction get a posi unit. turning off the entire ABS/TC/Stability Contol unit is not a smart thing.
what's the obsession with burning rubber anyways? I can turn off the TC and easily slide the car around corners safely with out this silly modification.
The reason for this mod is that if you take your car down the drag strip it will allow for better/easier launching an gaining a few extra tenths on your 1/4 mile times.
Also when i turn traction off i want it to be 'OFF' which it wasnt before this mod.
Also now i have complete control from the cabin rather than having to pull fuses or going under the hood.
Thanks for the 'Silly Mod' remark though, but there are alot of people here who have had real pains with this traction issue
Steve
